What caused the Error 400 when send complete form in Survey123 2.0?
2457
04-28-2017 06:13 AM
AdministratorAGOL_ODIMM
Hi everybody!
I published form in Survey123 Connect 2.0, but we can't sent a forms from Survey123 (2.0) Windows or Android in the result we get the same Error 400, like in image which I insert here.
Another forms from the same devices works ok.
I use mobile internet, attachments was not activated.
Maybe .xml schema is wrong? Form has complex structure with multiple relations maybe in some of this relations is a problem? I attached .xlsx schema.
Thanks in advance for your help.
JamesTedrick
Esri Esteemed Contributor
Hi Igor,
I think the issue is with some of your integer questions.  There appear to be calculations that involve very large numbers- the integer field can only store values from -2,147,483,648 to 2,147,483,647.  Setting those question types to text should address the issue.
ArcGIS field data types—ArcGIS Help | ArcGIS Desktop
James,
thank you for your answer, you were right. But I also found other mistakes when calculating the date.
Now everything works.
