Webhook Issues
2028
03-23-2020 12:37 PM
AaronNash__GISP
I am getting a [400] Invalid URL when using Integromat, as soon as a survey is submitted the error is logged and service is shut down. My connection to portal looks good, I can verify in Integromat.
I looked at using Microsoft Power Automate but it does not work with a local portal installation. So one will not work with ArcGIS Enterprise and the other keeps crashing. Any help would be appreciated.
AaronNash__GISP
I was able to resolve this error by removing survey info from the event data, not sure why that is creating an issue.
AaronNash__GISP
Shwu-jingJeng
Hi Aaron,
Did the same webhook service work before and now it stop working with 400 error? Did you also check the firewall issue?
Please double check this post to see if you miss anything:
https://community.esri.com/groups/survey123/blog/2019/06/04/survey123-tricks-of-the-trade-integromat
AaronNash__GISP
it never worked, i talked to our IT department and they told me "http/https is allowed to all of the Internet, and https is allowed from all of the Internet" so it does not appear to be a firewall issue blocking traffic to the server.
The only resolution was to remove survey info from the event data, now it works as expected.
