Warning (Yellow Flag) validation
2200
02-15-2017 04:59 PM
DanielMcIlroy
Is it possible (or is it functionality that is planned/coming) to expand the required field to allow for a "Warning" type message if a field is left blank?
We are designing a form for a field trip that allows no response to certain questions, however they would like it if a warning was displayed to the user that they had not completed the field but allowed the user to acknowledge it and still submit the survey.
JamesTedrick
Esri Esteemed Contributor
Hi Dan,
One way this can be accomplished is with a select_one/select_multiple that is used to override the constraint - the constraint function becomes
<Existing constraint> or ${overridefield} = <override value>
As an example:
(survey sheet):
typenamelabelhintconstraint
integervalue1Enter in the number of things(Normally 10 or less). < 10 or ${ok1} = 'override'
select_one okok1Confirm that the number is correct
(choices sheet):
list_namenamelabel
okoverrideValue is correct
DanielMcIlroy
Thanks James, this works great and I think will solve the problem. I will modify the constraint to look for a null value rather than a number range as the user wants to allow field users to not capture a value, but ensure that it wasn't missed by accident.
JamesTedrick
Hi Dan- great.  Make sure you pay attention to how null values are expressed - Formulas—Survey123 for ArcGIS | ArcGIS  provides guidance.
DanielMcIlroy
That formulas page is a fantastic resource, thanks for passing it on. I definitely came up against the null value brick wall!
Thank you so much for your help, I am trying to implement Survey123 for a large field campaign about to be undertaken so no doubt I will pop up with more questions!
