Want to Show Default Values Unless a Previous Question has a "No" Answer
201
06-05-2024 08:37 AM
StevenHughes
I have a select_multiple question with a default value set.  I want to keep the default value if the "if(selected)" statement answer is "No" and only select one of the default values if the "if(selected)" statement answer is "Yes".  Right now, I have the "Yes" value side of the "if(selected)" working, but I cannot keep my default values if the statement answer is "No".
abureaux
MVP Regular Contributor
Can you please provide more details? Like, including the entire logic statement, or ideally the XLSX so we can see the interaction. Honestly, XLSX would likely be most helpful here.
