View survey in Workforce
1073
03-12-2018 01:46 PM
MichelleDuncan2
I have Workforce integrated with Survey123 so when an assignment is created the mobile worker can access the survey from Workforce. Is there a way to see the survey submitted for that particular assignment within Workforce or is that survey only accessible through Survey123 and AGOL? We would really like to be able to see the survey in Workforce attached to the associated assignment.
Michelle
IsmaelChivite
Esri Notable Contributor
Hi.   The owner of the Workforce Project can customize the Web Map used in the Workforce mobile app.  You could have the owner add the Survey123 layer to the Workforce Mobile WebMap so people in the field can see the surveys added to the map.
MichelleDuncan2
That works. Thank you!
