Using web map from AGOL in Survey123- secured layers not loading anymore at 3.9?
716
04-23-2020 10:29 AM
JonahW
I have a survey that was created using Survey123 Connect v 3.7. I had a web map from my AGOL linked to this survey so I could use it as a basemap. Although it was slow to load it was working and all layers were loading fine. I recently upgraded to v3.9 and now my web map is only displaying the layers that were not secured (Note: we host the data on our own ArcServer and most of the map services are private). I also tried to temporarily remove the security on one of map services used it the web map. After doing this that particular layer started loading again. I know the "Standard" maps are still in Beta but was wondering if anybody else has experienced this.
JamesTedrick
Esri Esteemed Contributor
Hi Alina,
Apologies for the delay in response.  Could you go into the Early Adopter Community and try the latest beta of 3.10 and see if this issue is still occurring?
