Use Survey123 Webhooks with AWS?
1635
01-22-2020 09:57 AM
MikeSchonlau
Does anyone know of a way to use a Survey123 webhook with an AWS service (like Lambda and SNS) for notifications? Thanks
JamesTedrick
Esri Esteemed Contributor
Hi Michael,
Yes, this is doable.  https://medium.com/@yashishdua/building-webhook-is-easy-using-aws-lambda-and-api-gateway-56f5e5c3a59...  appears to provide a good guide on getting started with this.
MikeSchonlau
Thanks. I was hoping someone in the ESRI universe had tried it already, but I'll start tinkering with it and post any relevant results.
Javier_Pintos
Hi Mike, it works?
Thank you!
