Use an attribute's value as a default
990
08-14-2018 04:46 PM
MarkNorbury
I have a Survey123 survey that has a geopoint for one of its answers.  After the user has selected a location, I then want to use that location to query a polygon layer and populate a subsequent answer with an attribute value from that query.  Is this possible, or beyond the limits of what Survey123 can do?
JamesTedrick
Esri Esteemed Contributor
Hi Mark,
We are working on a feature to enable this sort of workflow in beta; you can get more information in the Esri Early Adopter Community.
