Uploading/Capturing multiple photos at one time
1495
05-14-2025 12:36 PM
SamuelSchneider
Hi all, I am looking to see if there is a way to upload or capture multiple photos in succession, then submit them to a question within Survey123. I have tried the multiline appearance already to attach multiple photos to a single question. I am just hoping to click the attach icon and select multiple photos out of my library at once, or take multiple photos quickly and attach without have to continue to click the photo capture button.
Any thoughts on this or solutions existing?
RyanUthoff
MVP Regular Contributor
If you create a "file" question in your survey with a multiline appearance, it will allow you to select multiple photos at a time. The downside is that it will allow users to upload more than just photos, but it will accomplish what you're asking.
Edit: It looks like someone made an ArcGIS Idea regarding this. https://community.esri.com/t5/arcgis-survey123-ideas/select-multiple-photos-to-upload-to-survey123/i...
RyanUthoff
Actually, you can use the body::accept column to limit the file type, such as .jpg.
https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformmedia.htm#ESRI_SECTION1_A2F2DA5ADD...
SamuelSchneider
Trying this now. I will update when I have a result!
Thank you for your response to my post!
