update error 400 & 401
15685
25
07-21-2017 09:24 AM
youngpark
Good evening, Ismael & James
it is very strange.  today, I was planning to update one of my surveys.  I downloaded from the server then updated a couple fields then I could not upload again. (i am getting error 400 and 401)  thus, I did UNDO all my changes, but I could not upload my survey.
I attached few reference screenshots.  I guess the "repeat" cause some issue.
please let me know if you have any idea.
thanks,
BradenBurkholder
This issue appears to be fixed. Can anyone confirm resolution?
JamesTedrick
Esri Esteemed Contributor
Hi Braden,
Yes, a fix for the issue was applied overnight.
James
BradenBurkholder
Thanks James!
RenatoSalvaleon
Is the fix on the server side?
by Anonymous User
Not applicable
Yes, the fix was on with the API on the server side, so does not require you to update Connect. If you can try to re-publish your survey again it should work now.
RenatoSalvaleon
philipwilson‌, I confirm that geopoint pulldata works for my surveys now.  Thanks!
