Undefined is Invalid Error Message
1976
03-23-2017 11:46 AM
DeenaBowman
Has anyone else received the "undefined is invalid" error message when attempting to submit survey response?  I'm having difficulty troubleshooting/isolating the error.  For example, I can submit one survey and then the next survey I attempt to submit will generate this error.  Could this be related to geopoint?  I eliminated the photo repeat and removed the submission URL, but still get this error.  The intent is that the Receiving Water (RW) station ids will use a geopoint captured from the device and the Storm Drain (SD) station ids will use the pullitem from a csv.
by Anonymous User
Not applicable
This error happened to me as well when I add a row "calculate" type. Now I need to remove that row and still wonder how can I use the calculate type without have the "Undefined is invalid" error shows up.
