Unable to successfully test a Power Automate flow using ArcGIS Enterprise connector
1062
05-26-2022 04:43 AM
ZacharyHart
Honored Contributor
I'm at a complete loss here. ArcGIS Enterprise 10.9.1.
I have existing webhooks via Portal that work with Power Automate just fine.
I have a very simple test survey and have created the ArcGIS Enterprise Connector as described here. The connector steps all validate correctly and the test webhook is created in the survey which I can see in Survey123 web designer.
When I add the custom connector to a new flow and add a simple step such as send an email and then save the flow, the new webhook is successfully registered with the Survey. When I attempt to test the flow it simply sits with a spinning icon which eventually times out.
  • There are no errors in Portal logs
  • There are no errors in the flow checker
  • If I submit a survey response, the associated Portal feature layer updates just fine, but this too fails to trigger the flow.
ZacharySutherby
Hello @ZacharyHart
I'm guessing since the connector steps all validated the answer to this is yes but is your ArcGIS Enterprise environment accessible over the internet?
If so after Survey123 sends the applyEdits request to the feature service it should also be sending a request to the payload URL of your webhook (which you should see on the Webhooks settings page in the Survey123 website). If you capture the web traffic while you submit a record are you seeing that request to the payload URL?
Thank you,
Zach
