Hi there
After an upgrade from 1.1.12 to 1.2.19 I can no longer login to our own portal ??
We had no problems in the old version, but now I get an "invalid user" or a code 400 ????
Anyone ??
we just published a KB article that will teach you how to prepare Portal for ArcGIS 10.3.1 to work with the newer versions of Survey123 for ArcGIS. Starting with 1.2.19 we use OAuth in the sign-in dialog. You will need to register the Survey123 AppIDs in the Portal.
I believe this may be the crux of your problem.
See more details here: Survey123 and ArcGIS for Server
Ismael
Hi Henrik,
some questions to help diagnose:
Hi Henrik,
the issue is caused by the fact that the latest update of Survey123 works with OAuth. For an OAuth client to be able to register against Portal for ArcGIS, it is needed that the Portal has a unique ClientAppID registered in the portal. Since 10.3.1 shipped before Survey123, this ClientAppID is missing.
Before OAuth was implemented in Survey123, you were able to login against your Portal and use Build-in users. Now with OAuth, Portal is not allowing Survey123 to connect. We are working with the Portal for ArcGIS Server team to figure how to resolve this.
This problem will not occur with Portal for ArcGIS 10.4. Our intent is that you will be able to continue testing Survey123 Beta against your Portal 10.3.1. Will get back to this post with more comments as soon as we have a solution.
Apologies for the inconvenience.
Ismael
Ismael
