Unable to add feature service definition code 400
1591
03-15-2019 09:23 AM
CUARTA_OPORTUNIDADLOCAL
When i try to publish my survey, I have this error.
I don't know which is the problem.
I attach the form of my survey
I need help, please!!!!!!!!
BrandonArmstrong
Hi Liliana,
Are you attempting to update a survey that had been previously published, or this is the first time you are publishing this survey using this XLSForm?  If you are updating, what happens when you try to create a new survey using the same XLSForm?
I received no error when publishing on my end.
Best,
Brandon
We have created it again and it worked! Thank you very much!
