Trim Function in Survey123
3501
09-27-2018 12:57 PM
DavidBuehler
Is it possible to use the trim function or some other method to remove unwanted spaces due to a concatenate in Survey123?  The idea is if an field can be parsed it should be parsed from the start.  Address example 100 S Vine Ave.  100 would be in one field, S in another, and so on.  However, to run that address against a single field geocoder or even used in a form letter for a mailing (like Dear resident at 100 S Vine Ave), I need it in a single field.  When concatenated and lets say the directionality is not part of the street name (100 Vine Ave), you would get extra space so 100--Vine-Ave instead of 100-Vine-Ave
trim((${houseno_txt})+ " " + (${stdirectionnospace_txt}) + " " + (${street_txt}) + " " + (${streettype_txt})) doesn't work, and =trim((${houseno_txt})+ " " + (${stdirectionnospace_txt}) + " " + (${street_txt}) + " " + (${streettype_txt})) gives an error from a formula stand point.
Any suggestions?
DavidBuehler
Figured one way out:
if(${stdirection_so}= "None", '', ' ' + ${stdirection_so})
 in the field that returns the direction followed by
concat(${houseno_txt}+ ${stdirectionnospace_txt} + ' ' +  ${street_txt} + ' ' + ${streettype_txt})‍
in the field that generates the results.
DavidBuehler
