Toggle a page visibility
1406
12-20-2023 08:28 AM
CamKenny2
I was sent an xlsform for a survey.  I am going through the survey line by line and there is one setting that I cannot seem to find an answer for.
It is on a Page and the esri:body:visible is set to 1=2
The page doesn't show up when loading the survey in 123, so I am curious as to what this setting actually does.
I removed that setting and yes, the page will load but I cannot understand the syntax for 1=2
Katie_Clark
MVP Regular Contributor
To me, this seems like a way to make the page always hidden (not sure why you would need to do that?)
But since 1=2 will always evaluate to false, the condition will never be met so the page will never display in the survey. Maybe the entire page contains questions that contain data only needed on the backend for data processing or something?
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
Best,
Katie
CamKenny2
Ahhh, yes, this makes sense to me.  The page does in fact contain data that is needed on the backend that is automatically populated such as deviceid etc.
