Thank you screen html visible
2129
04-25-2017 11:00 AM
NormanOrellana
Hello, my name is Norman from IDS Ecuador, I have been testing survey123 in the web designer, and I found a issue.
In the title of my survey I put some html code and looks great, but at the end when I sent the survey and the thank you screen message is showed the html from the title appears, there is a way to fix it?
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Norman,
Thanks for pointing that out- I'll file an issue to fix the html interpretation on the post-submission screen
JamesTedrick
Hi Norman,
NormanOrellana
Thanks James for your answer
ZhifangWang
Hi norellanaidsecuador-esridist
Just FYI, we have the enhancement implemented for 2.8 release (planned in mid May), you can set rich text content directly in the web designer then.
