Syntax for email address field input mask?
9758
03-29-2018 07:20 AM
BrentKinal1
I feel like in a past post I saw some syntax for using an input mask for an email address field, If I wasn't dreaming this and one exists please share the syntax.
Thanks!
Brent
JamesTedrick
Esri Esteemed Contributor
Hi Brent,
Input masks don't work with arbitrary length text portions, as you would expect from parts of an e-mail address.  As  documented, you can use a regex function to validate an email address:
regex(., '^(([^<>()\[\]\\.,;:\s@"]+(\.[^<>()\[\]\\.,;:\s@"]+)*)|(".+"))@((\[[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}])|(([a-zA-Z\-0-9]+\.)+[a-zA-Z]{2,}))$')
JamesTedrick
Hi Brent,
GISManager4
Hi, @JamesTedrick I tired the syntax in the constraint field, but it doesn't appear to work on Connect v3.22.49
Survey123Jedi
@JamesTedrick
I'm getting this text populating 3.14 Survey123 Connect.
I haven't used the email body::esri:inputMask in a while, what am I doing wrong?
IgorAtamanchuk
The regex needs to be inputed into the "constraint" column in your XLSForm. Also, it seems like the preview won't show the validation, but it works well when the form in published. Hope this helps
