I’m pretty new to Survey123 so I apologize if this has been discussed before.
I created a survey that has about 13 pages. Most of the surveys will be completed on a desktop. When testing, I noticed that while on the desktop you can still navigate pages by swiping (clicking a dragging the mouse horizontally). I didn’t think it would cause any issues, but when I sent it out to other staff to test they said it would change pages when they highlight text and when using the map (geopoint). Is there a work-around or a way to turn off the swiping when using desktop?
Thanks!
Hi Conor,
To check, you are referring to the web form version of the survey, yes? I've added an enhancements to disable swipe in desktop contexts.
Hi James,
I’m using the XLSForm version through the Connect application. Sorry, I forgot to mention that in the original post.
