Surveys with long repeat fields
5359
12
01-16-2017 03:52 PM
nejibco
Hi All, is it possible to define a dynamic title for the survey?
In the case of surveys containing long repeat fields where the person collection data can get lost by going up and down, the title is a great choice to indicate which particular field he is currently surveying. For example, the title can be defined as follow:
                                                   Title =  concat('SurveyName:',  ${currentFieldName})
 The idea is, while collecting data, the user will be able to check from the title which particular field he is collecting.
by Anonymous User
Not applicable
Hi James, any update on this?
In our bird survey form, we have one "bird count" repeat that's pretty basic: select species, enter count
The field team is requesting to see a list of the species w/counts before they submit, to ensure they recorded every species they saw in the 2 minutes they're allotted to survey all the birds in the area. I haven't been able to figure this out, rather I've set the instance name as concat (${survey_id}, ": ", count(${species}), " count records") so they see the number of species records they submitted. But what they really want is to see a list of species.
Any thoughts/advice?
IsmaelChivite
Esri Notable Contributor
Hi. You may want to check the Aggregation Functions (join) section in https://community.esri.com/groups/survey123/blog/2020/04/09/survey123-tricks-of-the-trade-repeats
nejib co‌  Katie Andrews‌  The join function, as described in the blog, can be used in an inline note question, to feed the label of a repeat, group or instance_name.
by Anonymous User
Not applicable
Thank you Ismael, I used the join (join(",",${species})) to create a read-only text field showing a running list of the species being recorded; the output reads like this: American Avocet, Dunlin, Blue-winged Team.
What I continue to try without success is to use the join function to create a list of a concatenation of two fields ${count} and $(species}, so the result would look something like 10 American Avocet, 200 Dunlin, 50 Blue-winged Teal. I've played with a few ways of doing this but am not getting it right. Is this possible? Thanks.
