Survey123connect Initialization o.split is not a function
2181
04-30-2020 05:13 PM
JimKyle
I have a Survey123 connect application that is now issuing an error on startup.  Basically it is getting Error.Initializing Form... Type error:  o.split is not a function.   I believe this error is new.
Any idea were I should look within the xlsx to determine what is causing this?
Thanks.
by Anonymous User
Not applicable
Hi Jim,
It sounds as if there is an expression in one of the calculation/constraint/relevant columns that is not valid. Can you please share the xlsx file so we can take a closer look?
Regards,
Phil.
JimKyle
Thanks.  I attached the form to the original message if you want to have a look. It's a work in progress.
by Anonymous User
Not applicable
Hi Jim,
I tried the xlsx form file you uploaded to your original post, and can not reproduce your error with latest 3.9 version of Connect. I do not get an initializing error and the form loads correctly in Connect and I can publish and collect surveys. Have you tried re-installing Connect or opening on another computer?
Regards,
Phil.
