Survey123 without thank you screen
1446
06-20-2023 05:16 AM
K_Schouten
Is it possible to submit a survey without the thank you screen appearing in the Survey123 web app.
IsmaelChivite
Esri Notable Contributor
@K_Schouten @Richard_Purkis
A new Quick Fix Release is now available. You can now configure the Thank You screen to reload your survey after 0 seconds. Effectively, this creates a survey without a Thank You screen! Details here: https://community.esri.com/t5/arcgis-survey123-blog/arcgis-survey123-june-2023-quick-fix-release/ba-...
IsmaelChivite
K_Schouten
Is this also possible with a survey made with Connect?
Richard_Purkis
@K_Schouten
Yes the panel to configure the Thank You screen is available for surveys published from the Web Designer or Connect.
Hope this helps
K_Schouten
@Richard_Purkis
Thanks, this is working.
