Survey123 with portal using Self-signed certificate
2253
09-05-2018 10:13 AM
khalilramadeen
New Contributor III
Is there any way to enable "Ignore SSL Errors" in Survey123 connect?
The version I use is V.3.0 like previous versions (See attached)@
I need to connect Survey123 with Portal for ArcGIS while my current certificate is Self-signed certificate.
Ismael Chivite
James Tedrick
Thanks in advance,
Khaleel
JamesTedrick
Esri Esteemed Contributor
Hi Khalil,
If your ArcGIS Enterprise is using a self-signed certificate, you can add that certificate to your devices' trust store to enable access.  Alternatively, you may want to get a trusted SSL certificate for your computing environment- see Configure HTTPS using a new CA-signed certificate—ArcGIS Server Administration (Windows) | ArcGIS En...
JamesTedrick
Hi Khalil,
khalilramadeen
New Contributor III
Thank you James.
Khalil,
ChristopherEby2
New Contributor III
James Tedrick‌ I'm running on Windows and I installed my certificate to the Trusted Root Certification Authorities but I'm still getting the error.
JamesTedrick
Hi Chris,
To confirm, you are able to view the Portal website without SSL error in IE/Chrome on the same computer?
