Survey123 with Collector: set geotrace
12241
20
04-29-2019 12:45 PM
Marc-AndreBedard
Hi !
is there a way to pass the location of a line in collector "Aurora" to Survey123 in the same way of passing the location to a geopoint in survey123 ?
Thanks to great thread https://community.esri.com/groups/survey123/blog/2016/07/30/understanding-survey123s-custom-url-sche...  from https://community.esri.com/people/ichivite-esristaff and https://community.esri.com/people/JTedrick-esristaff
TaraHaynes
Hey! I've been trying to figure this out, but it seems I don't have permission to view your survey - does the shape text translate to a shape on a map within the Survey123 form, or is it simply saved as text?
RustyCook
Was this ever solved? Im trying to pass the coordinates for a polygon via url but no luck on getting it to show up on the map within the survey.
?field:<geoshape field name>=47.31507205963135%20-122.41456244885921;47.314385414123535%20-122.41456244885921
ChrisRoberts2
This works for me.  Below is the Arcade script I created:
var geom = Geometry($feature);
var firstpart = geom.rings[0];
var originShift = 2.0 * PI * 6378137.0 / 2.0;
var outparts = [];
var counter = 0;
for (var pt in firstpart){
    var long = (firstpart[pt].x / originShift) * 180.0;
var lat = (firstpart[pt].y / originShift) * 180.0;
lat = 180.0 / PI * (2.0 * Atan( Exp( lat * PI / 180.0)) - PI / 2.0);
var lat =Round(lat, 5)
var long =Round(long, 5)
var ptstr = Concatenate(lat, " ", long);
outparts[counter]= ptstr;
Then create a hyperlink in the pop up:  "arcgis-survey123://?itemID=xxxxxx&amp;field:Polygon={expression/expr0}"
With Polygon being the geotrace question in the survey
You might notice in my Arcade that I round the lat and long returns down to 5 decimal places.  I found that leaving them as default would often fail for slightly complex polys which I think is due to the overall length of the url it produces.
Hope that helps
Chris
RustyCook
Thanks! Could you share what the url looks like, just the geometry part? Im passing the geometry through the REST API so I may have to format it within the script before passing it over in a similar fashion just different language. Also Im using a geoshape, not trace. Do you know if thats possible?
ChrisRoberts2
The Arcade expression is for the geoshape question, sorry miss typed there.
Here is one that copies a selected parcel in Explorer and parses the polygon to a Survey123 form (the bit in italics is what you want I think).  Note I also capture the centroid of the Parcel so I can perform a reverse geocode in Survey123 to get the address
arcgis-survey123://?itemID=xxx&field:dcdbid_1=F112784A2&field:ct=CT&field:volume=5203&field:folio=279&field:LandholderLiaisonParcels_polygon=-35.03596%20138.83725%3B-35.03959%20138.8346%3B-35.03807%20138.83162%3B-35.0355%20138.83349%3B-35.03549%20138.83348%3B-35.03446%20138.83422%3B-35.03596%20138.83725&field:longitude=138.8344310701019&field:latitude=-35.03701676138787
RustyCook
Thanks Chris for the help! So I tested it but it doesn't translate to a shape on a map within the Survey form; is it just saved as text in the background?
ChrisRoberts2
Hi Rusty
Not sure why its not working for you, perhaps you could share the xlsform, and if I get a chance I'll have a look and see if there is anything obvious? If you parse the coordinates to the appropriate geoshape question in the form then in should  work  - field:LandholderLiaisonParcels_polygon=-35.03596%20138.83725%3B-35.03959%20138.8346%3B-35.03807%20138.83162%3B-35.0355%20138.83349%3B-35.03549%20138.83348%3B-35.03446%20138.83422%3B-35.03596%20138.83725
RustyCook
Attached is what I have. I haven't built this out as I'm only using this as my test/sandbox survey.
?field:geofence=-35.03596%20138.83725%3B-35.03959%20138.8346%3B-35.03807%20138.83162%3B-35.0355%20138.83349%3B-35.03549%20138.83348%3B-35.03446%20138.83422%3B-35.03596%20138.83725
Thanks for taking a look!
AprilChipman
James - I've been trying to get this to work in my data, but cannot get the custom url to pass the geometry of a line to the survey. It's passing other field attributes, so I know the url syntax is working.
When I test the 'Shape as String' expression I get really weird values. Could this be my problem? If so, how is it coming up with these coordinates and how can I make it stop?
MaryGraceMcClellan
@JamesTedrick - I would love your feedback on the reverse of this question I just posted here: https://community.esri.com/t5/arcgis-survey123-questions/javascript-snippet-to-get-a-vertex-from-a-g...
