Survey123 Web Designer - Instance Name
2094
02-01-2022 11:37 AM
BrandonA_CDPH
Hi!
I am working on a form in Web Designer and would like to change the Instance Name in the Field App. I can find documentation on how to change the Instance name using connect, but can't find anything that definitively says this can or cannot be done in the web designer. Anyone out there have a definitive answer? I'm pretty sure it's a no, but asking in case.  Thanks.
by Anonymous User
Not applicable
Hi @BrandonA_CDPH,
It is not possible to set or change the instance name via the web designer. This setting is only available in Connect and is used by the field app when viewing surveys in the Inbox list or map views (as well as drafts, sent, outbox etc).
Regards,
Phil.
by Anonymous User
Not applicable
Hi @BrandonA_CDPH,
Regards,
Phil.
BrandonA_CDPH
That was the answer I expected, but was hoping wasn't true. 🙂  Thank you for the reply!
