Survey123 Web Designer calculation function
827
10-31-2024 11:39 AM
Tiff
Can the Survey123 web designer calculation pull from layers that are non-hosted and are shared from enterprise geodatabases/ArcGIS Enterprise? I am struggling to find documentation stating what layers can be used as input for both calculations and dynamic choice lists.
If known, can this be confirmed? I cannot tell if it is the hosted/non-hosted issue, or if sync needs to be turned on for services published from enterprise geodatabases.
1.  I just tested this out (on a temporary layer as we do not have sync turned on for enterprise layers just yet) and it looks like it works. However, can this be more clearly stated in the documentation?
2. I have found a situation where the calculation can pull from a service from enterprise database that does NOT have sync enabled so now I am even more confused. One big difference is that layer has editing enabled.
3. Occasionally even if shared to the organization through distributed collaboration, there is a 498: Invalid Token or 499: Invalid Token error.
If anyone can point me to the right resources or documentation, greatly appreciated. Thanks!
