Survey123 Web App Embeddable?
2676
06-07-2018 11:33 AM
ReedShoho1
Can you embed the Survey123 web app for use with other applications, such as Workflow Manager? Are other methods of integrating these two products available?
JamesTedrick
Esri Esteemed Contributor
Hi Reed,
Like any other web page, teh Survey123 web form can embedded in another web page using an <iframe> or <object> tab.  Using the parameter embed=true in the URL will slightly alter the layout to better work with an embedded context.  In the future, we plan to make it easier for survey authors to generate the embedding HTML code via the Survey123 website.
ReedShoho1
Ok thank you!
