Survey123 Using Conditional Calculations to auto-populate fields
9880
10
02-17-2018 07:24 AM
JoshHabel
Hello,
I am working on a utility pole inspection form that will have multiple questions and am trying to figure a way to create a shortcut field (Quick_Pick) that will auto populate these questions when either everything is Okay or they cannot inspect the pole while still allowing them to choose other answers if needed.  So far I have the following questions setup.  Both fields are select_one type with their corresponding choice lists.
Field Name               Choices
Quick_Pick               "OK" or "No Inspect"
Pole_Condition        "OK" or null
Ive been hacking around trying to create a calculation on the Pole_Condition field without any success.  Below is my latest failed attempt.  Is what I'm trying to do even possible and if so what am I doing wrong?  Any help would be appreciated!
if(selected(${Quick_Pick},'OK'),'OK', or selected(${Quick_Pick}, 'No_Inspect'), 'null')
Josh
JohnathanHasthorpe
Hi Josh
If I understand you correctly - you want to update pole_condition based on the answer in quick_pick. If so then the following should work:
 if(selected(${Quick_Pick},'ok'),'OK', if(selected(${Quick_Pick},'no_inspect'),'null', ''))
- if you select OK in quick_pick then we will select ok in pole_condition
- else if you select no_inspect in quick_pick then we will select null in pole_condition
- else we return nothing
Note that 'null' would be a choice in your list in the above.
I hope this helps
Thanks
John
JoshHabel
John,
Unfortunately that did not work either. The only way i can get it to work is to turn the field with the calculate statement into a "text" field which of course defeats my purpose.
Josh
JohnathanHasthorpe
Hi Josh
Sorry - I should have mentioned that calculations in select_one questions are not currently supported. The good news is that they will be at 2.7 and you can test the functionality out in the Early Adopter Community now.
Thanks
John
SueJohnston
Hi John,
I'm working with version 2.7.72 now and i'm unable to get my calculation on a select_one to work.  I want my select_one to pick "Not Started" if any of my other questions = "yes".  i had this working as a hidden text field no problem, but we'd like to update this status field after the initial survey is collected.  I haven't been able to find an example of how to accomplish this, i hope you can help.
Thanks!
Sue
JohnathanHasthorpe
Hi Sue
Please see attached
Thanks
John
SueJohnston
Thanks Johnathan, I was able to get this to work!
TimFlynn
Is it possible to use multiple questions to auto fill a question?  I've got a couple of inspection forms where it will say something along the lines of, "A 'No' to any of questions 1-5 results in a Failed inspection."  I'm using Survey123 Connect version 2.4.6 (not able to upgrade without admin approval).  I've got it set up as a select one and for right now that's fine, but if I can automate out any human error that would be great.
Would something like this work?  I'm not sure how to add multiple conditions.
if(selected(${Q1}and${Q2}and${Q3}and${Q4}and${Q5},'Yes'),'Pass', if(selected(${Q1}or${Q2}or${Q3}or${Q4}or${Q5},'No'),'Fail', ''))
Thanks!
JamesTedrick
Esri Esteemed Contributor
Hi Tim,
Each question should be evaluated in their own selected() function and joined.  In your case, if you want Q1-5 to be 'Yes', you do not need the second set of evaluations:
if(selected(${Q1}, 'Yes') and selected(${Q2}, 'Yes') and selected(${Q3}'Yes') and selected(${Q4}'Yes') and selected(${Q5},'Yes'), 'Pass', 'Fail')
TimFlynn
James this worked perfectly, thank you!
