Looking for the attach file...apologies. Don't see in in the reply.
<14>1 2019-01-09T23:00:58Z CND7222VX4 Survey123ConnectforArcGIS 9776 - - $ Logging started: 2019-01-09T18:00:58
<14>1 2019-01-09T23:00:58Z CND7222VX4 Survey123ConnectforArcGIS 9776 - - $ Application Name: Survey123ConnectforArcGIS
<14>1 2019-01-09T23:00:58Z CND7222VX4 Survey123ConnectforArcGIS 9776 - - $ Application Version: 3.1.126
<14>1 2019-01-09T23:00:58Z CND7222VX4 Survey123ConnectforArcGIS 9776 - - $ Application File Path: C:/Users/SLAVALLEE/Applications/ArcGIS/Survey123ConnectforArcGIS/Survey123ConnectforArcGIS.exe
<14>1 2019-01-09T23:00:58Z CND7222VX4 Survey123ConnectforArcGIS 9776 - - $ Application Directory Path: C:/Users/SLAVALLEE/Applications/ArcGIS/Survey123ConnectforArcGIS
<14>1 2019-01-09T23:00:58Z CND7222VX4 Survey123ConnectforArcGIS 9776 - - $ AppFramework Version: 3.1.113
<14>1 2019-01-09T23:00:58Z CND7222VX4 Survey123ConnectforArcGIS 9776 - - $ Qt Version: 5.10.0
<14>1 2019-01-09T23:00:58Z CND7222VX4 Survey123ConnectforArcGIS 9776 - - $ Operating System: Windows 7 SP 1 (6.1)
<14>1 2019-01-09T23:00:58Z CND7222VX4 Survey123ConnectforArcGIS 9776 - - $ Operating System Type: windows
<14>1 2019-01-09T23:00:58Z CND7222VX4 Survey123ConnectforArcGIS 9776 - - $ Operating System Version: 7sp1
<14>1 2019-01-09T23:00:58Z CND7222VX4 Survey123ConnectforArcGIS 9776 - - $ Kernel Type: winnt
<14>1 2019-01-09T23:00:58Z CND7222VX4 Survey123ConnectforArcGIS 9776 - - $ Kernel Version: 6.1.7601
<14>1 2019-01-09T23:00:58Z CND7222VX4 Survey123ConnectforArcGIS 9776 - - $ Build ABI: i386-little_endian-ilp32
<14>1 2019-01-09T23:00:58Z CND7222VX4 Survey123ConnectforArcGIS 9776 - - $ Current CPU Architecture: x86_64
<14>1 2019-01-09T23:00:58Z CND7222VX4 Survey123ConnectforArcGIS 9776 - - $ Build CPU Architecture: i386
<14>1 2019-01-09T23:00:58Z CND7222VX4 Survey123ConnectforArcGIS 9776 - - $ SSL Library Version: OpenSSL 1.0.2o 27 Mar 2018
<14>1 2019-01-09T23:00:58Z CND7222VX4 Survey123ConnectforArcGIS 9776 - - $ Host name: CND7222VX4
<14>1 2019-01-09T23:00:58Z CND7222VX4 Survey123ConnectforArcGIS 9776 - - $ Domain name: hq.menv.com
<14>1 2019-01-09T23:00:58Z CND7222VX4 Survey123ConnectforArcGIS 9776 - - $ Default locale: en_US
<14>1 2019-01-09T23:00:58Z CND7222VX4 Survey123ConnectforArcGIS 9776 - - $ Release Type: store
<15>1 2019-01-09T23:01:16Z CND7222VX4 Survey123ConnectforArcGIS 9776 - [AppStudio@11205 category="qml" function="expression for onStateChanged" filename="Portal.qml" line="214"] qml: Application state changed: 2
<15>1 2019-01-09T23:02:00Z CND7222VX4 Survey123ConnectforArcGIS 9776 - [AppStudio@11205 category="qml" function="expression for onStateChanged" filename="Portal.qml" line="214"] qml: Application state changed: 4
<15>1 2019-01-09T23:02:00Z CND7222VX4 Survey123ConnectforArcGIS 9776 - [AppStudio@11205 category="qml" function="reset" filename="Portal.qml" line="620"] qml: Token expiry timer not restarted
<15>1 2019-01-09T23:02:04Z CND7222VX4 Survey123ConnectforArcGIS 9776 - [AppStudio@11205 category="qml" function="write" filename="Config.qml" line="92"] qml: Saving Configuration
<15>1 2019-01-09T23:02:04Z CND7222VX4 Survey123ConnectforArcGIS 9776 - [AppStudio@11205 category="qml" function="log" filename="Config.qml" line="109"] qml: Configuration -
<15>1 2019-01-09T23:02:04Z CND7222VX4 Survey123ConnectforArcGIS 9776 - [AppStudio@11205 category="qml" function="log" filename="Config.qml" line="111"] qml: * fontFamily: Avenir Next LT Pro
<15>1 2019-01-09T23:02:04Z CND7222VX4 Survey123ConnectforArcGIS 9776 - [AppStudio@11205 category="qml" function="log" filename="Config.qml" line="112"] qml: * textScaleFactor: 1
<15>1 2019-01-09T23:02:04Z CND7222VX4 Survey123ConnectforArcGIS 9776 - [AppStudio@11205 category="qml" function="log" filename="Config.qml" line="113"] qml: * apiUrl: https://survey123.arcgis.com/api
<15>1 2019-01-09T23:02:04Z CND7222VX4 Survey123ConnectforArcGIS 9776 - [AppStudio@11205 category="qml" function="log" filename="Config.qml" line="114"] qml: * ignoreSslErrors: false
<15>1 2019-01-09T23:02:04Z CND7222VX4 Survey123ConnectforArcGIS 9776 - [AppStudio@11205 category="qml" function="write" filename="Config.qml" line="99"] qml: apiUrl https://survey123.arcgis.com/api
<15>1 2019-01-09T23:02:04Z CND7222VX4 Survey123ConnectforArcGIS 9776 - [AppStudio@11205 category="qml" function="write" filename="Config.qml" line="100"] qml: ignoreSslErrors false
<15>1 2019-01-09T23:02:11Z CND7222VX4 Survey123ConnectforArcGIS 9776 - [AppStudio@11205 category="qml" function="read" filename="PortalsList.qml" line="68"] qml: Empty portal list: SyntaxError: JSON.parse: Parse error
<15>1 2019-01-09T23:02:11Z CND7222VX4 Survey123ConnectforArcGIS 9776 - [AppStudio@11205 category="qml" function="setPortal" filename="Portal.qml" line="1133"] qml: setPortal: {
"objectName": "",
"externalUserAgent": false,
"ignoreSslErrors": false,
"isPortal": false,
"name": "ArcGIS Online",
"networkAuthentication": false,
"singleSignOn": false,
"supportsOAuth": true,
"url": "https://www.arcgis.com"
<15>1 2019-01-09T23:02:11Z CND7222VX4 Survey123ConnectforArcGIS 9776 - [AppStudio@11205 category="qml" function="signOut" filename="Portal.qml" line="187"] qml: signOut
<15>1 2019-01-09T23:02:11Z CND7222VX4 Survey123ConnectforArcGIS 9776 - [AppStudio@11205 category="qml" function="writeSettings" filename="Portal.qml" line="896"] qml: Write portal settings: ArcGIS Online url: https://www.arcgis.com isPortal: false ignoreSslErrors: false supportsOAuth: true redirectUri: urn:ietf:wg:oauth:2.0:oob externalUserAgent: false networkAuthentication: false singleSignOn: false
<15>1 2019-01-09T23:02:11Z CND7222VX4 Survey123ConnectforArcGIS 9776 - [AppStudio@11205 category="qml" function="updateRedirectUri" filename="Portal.qml" line="1161"] qml: updateRedirectUri: urn:ietf:wg:oauth:2.0:oob
<15>1 2019-01-09T23:02:11Z CND7222VX4 Survey123ConnectforArcGIS 9776 - [AppStudio@11205 category="qml" function="updateRedirectUri" filename="Portal.qml" line="1162"] qml: appName: Survey123ConnectforArcGIS installName: Survey123ConnectforArcGIS standalone: true singleInstance: true appRedirect: arcgis-survey123connect://localhost/oauth2/approval true
<15>1 2019-01-09T23:02:12Z CND7222VX4 Survey123ConnectforArcGIS 9776 - [AppStudio@11205 category="default"] bool __thiscall AbstractSocket::bind(const class QJSValue &,unsigned short,enum AbstractSocket::BindMode) "239.255.255.250" 1900
<15>1 2019-01-09T23:02:12Z CND7222VX4 Survey123ConnectforArcGIS 9776 - [AppStudio@11205 category="qml" function="onStateChanged" filename="SSDPListener.qml" line="84"] qml: SSDPListener status: 4
<15>1 2019-01-09T23:02:13Z CND7222VX4 Survey123ConnectforArcGIS 9776 - [AppStudio@11205 category="qml" function="expression for onStateChanged" filename="Portal.qml" line="214"] qml: Application state changed: 2
