Survey123 sqlite database corrupt
1710
06-05-2018 01:51 PM
Jean-YvesLandry1
One of my tablets crashed and the surveys disappeared from the application.  I copied the .sqlite database to my computer (~8mb) but when I open it the "Surveys" table appear empty. However, when I opened the sqlite in notepad ++ , I can see that the surveys are still there.
I've followed various recovery measures, such as  Procedure to recover a corrupted SQLite3 ArcGIS Mobile cache database, but they only dump an empty table.
I've reverted back to a previous .sqlite backup but since this is the first time that I've had an .sqlite database corrupt with Survey123 I was wondering if anyone else has had this happen and what you did to repair the database.
Tags (1)
by Anonymous User
Not applicable
Hi Jean-Yves,
Are you able to share a copy of the corrupt sqlite database so we can take a look, provided the data is not sensitive or confidential. I haven't seen an exact issue like with the sqlite database and Survey123, but if we can investigate further with your database that would be helpful.
Phil.
Jean-YvesLandry1
I can't share publicly, but message me privately please.
by Anonymous User
Not applicable
Hi Jean-Yves,
I have sent you a private message with my contact details. Once you send through the sqlite db I will take a look and get back to you.
Phil.
