Survey123: Split answers from multiple_select
5047
01-20-2020 06:29 AM
Nicole_Ueberschär
I am pretty sure that I saw this problem solved somewhere already but I cannot find it.
Assuming that I have a multiple_select answer that has the selected answers concatenated by a comma:
Banana, Apple, Orange, Strawberry, Tree_Tomato
Now I would like to save these answers to different columns (=questions) in my survey
First Answer: Banana
Second Answer: Apple
Third Answer: Orange
Fifth Answer: Tree_Tomato
How can I extract the answers separately depending on their position?
Alain Roland Munyaneza
Jim-Moore
Hi Nicole
This can be achieved using the selected-at() function, which will return the name for the choice at the given position. Note that this is indexed from zero. For example, to return the name of the third selected choice:
selected-at(${fruit},2)
This function is described here: https://community.esri.com/groups/survey123/blog/2018/12/02/survey123-tricks-of-the-trade-xlsform-fu...
And also documented here Formulas—Survey123 for ArcGIS | Documentation and here XLSForm essentials—Survey123 for ArcGIS | Documentation.
Cheers,
Jim
Jim-Moore
Hi Nicole
Cheers,
Jim
Nicole_Ueberschär
Thanks a lot, I should have looked into the documentation first...
Any hint how I could split up a text when several answers are give in a free text question? When I give the option to list "others" and the user fills "Avocado, Cucumber, Tomato, Corn", is there a way to save those also separated in additional columns/questions? I found a lot in excel for only three values (like left, mid, right) but couldn't figure out how to do it with more than three items in the list.
Jim-Moore
Hi Nicole
As mentioned in this post, there isn't a function for this in XLSForm. A JavaScript function (currently in beta) could help (refer to EAC).
For a calculation to work, users would have to type their list of additional entries in a strict format, which could be difficult to enforce. If your aim is to write each entry to a separate question anyway, one suggestion is to have one question per additional input; you could use something like string-length({$previous})>0 in the relevant column to hide the next question until it's needed. This would avoid issues with inconsistent data entry into a single text question.
One consideration with this approach is you would need to have a capped number of additional entries (questions).
Hope this helps!
Cheers,
Jim
Nicole_Ueberschär
Thanks a lot Jim!
