Survey123 share link not functioning
1078
08-21-2017 03:02 PM
JeffPowell1
After publishing a Survey123 form using the Web App interface with no errors or known issues, the survey will load through the "Share" URL link found on the collaborate page. However, the "webclient" version of this survey URL stalls upon opening the new browser. The link to the survey is below in the two forms:
1. https://survey123.arcgis.com/share/1672bce7ad324acdae35f557e8c5d2cc
2. https://survey123.arcgis.com/webclient/1672bce7ad324acdae35f557e8c5d2cc
by Anonymous User
Not applicable
Hi Jeff,
I was successfully able to open both links, note that the "webclient" url should now forward to the "share" url.
What browser version and OS are you using? Can you clear the cache in the browser and retry, or try using a different browser and see if it then works?
Regards,
Phil.
