Hi
I'm having trouble creating a report that has a location question (map) in it.
The report cannot be generated and after a few minutes the following error message is received:
${EventLocation} is the point location question in the form.
When I delete the location question from the template, the report is generated successfully.
Any Ideas what can be the issue, and how to fix it?
Guy
Hi Guy,
As the error indicates, there is a maximum time (3 minutes/180 seconds) for the feature report service to generate the map before it is considered a 'failed' operation. Are you specifying a specific map and/or zoom scale?
Hi James,
Thanks for your help.
No, I try the simplest way, just with the question ($), no
scale or zoom specifications.
Guy
ᐧ
בתאריך יום ג׳, 31 במרץ 2020 ב-1:33 מאת James Tedrick <[email protected]
GeoNet, The Esri Community | GIS and Geospatial Professional Community
<https://community.esri.com/?et=watches.email.thread>
Re: Survey123 Report - Location Question Problem
reply from James Tedrick
<https://community.esri.com/people/JTedrick-esristaff?et=watches.email.thread>
in Survey123 for ArcGIS - View the full discussion
<https://community.esri.com/message/918797-re-survey123-report-location-question-problem?commentID=918797&et=watches.email.thread#comment-918797>
What is the default basemap of your form? Is it an ArcGIS Online basemap or one that is custom to your organization?
Custom to my organization.
ᐧ
בתאריך יום ג׳, 31 במרץ 2020 ב-20:00 מאת James Tedrick <[email protected]
<https://community.esri.com/message/919039-re-survey123-report-location-question-problem?commentID=919039&et=watches.email.thread#comment-919039>
