Survey123 Report dates off by one
3829
10
11-19-2018 08:34 AM
GingerHarrington
I am using Survey123 for inspections.  They inspections are completed monthly and I have created the report as a Word document to print the inspection.  I have been using this data and information all year.  I have in my data 6 dates.  The date is correct in Survey123; however when I generate the report, the date shows up as 1 day earlier for October but not November.  (Example data entered as October 9 but shows up as October 8.) This error did not occur last month.  Any ideas?
JamesTedrick
Esri Esteemed Contributor
Hi Ginger,
That could be a solution; there are a couple of others.
For already collected data, you could either re-calculate the answer with +1 hour or create an Arcade Expression to do the same in a 'calculated' column.
To ensure new data is collected correctly, for datetime questions you could change the today() function to the following calculation:
decimal-date-time(today()) + (1 div 24)
This won't work for date questions, however
