Survey123 Report Conditional Formatting with number ranges
3638
11-17-2023 04:36 AM
BrendonJoyce1
Good morning all,
I am trying to put some conditional formatting in a Survey123 Report. I'd like to have a certain hydrant class show with color formatting for each report based on a flow in GPM in an integer field.
The formatting at both AA & C with just the >= or <= statements work for formatting, but I am having trouble with class A & B with the ranges. It doesn't appear to format the same way I am used to.
${if flow20 >=1500} hydrant class: AA${/}
${if 1000<= flow20 <=1499} hydrant class: A${/}
${if 500<= flow20 <=999} hydrant class: B${/}
${if flow20 <=499} hydrant class: C${/}
The report template is accepted, and when running reports, it seems that they are grabbing multiple classes regardless of the expression. I think I am missing some formatting.
Any help would be greatly appreciated, thanks!
abureaux
MVP Frequent Contributor
You need to do it like this:
${if flow20>=1000 && flow20<=1499} hydrant class: A${/}
EDIT: For additional logical operators in Feature Reports, check out the table at the bottom of this page.
abureaux
BrendonJoyce1
@abureaux Thank you, this works as intended. I had tried with "AND" and it didn't work.
Much appreciated!
