Survey123 Repeats and Geopoint
5412
22
08-14-2023 06:59 PM
KathyFulton
I have created a survey to capture details about resources available at a particular location. I have basic information (organization, contact, etc) outside of the repeat, then within the repeat I ask for the location (using geopoint) and specific characteristics about that location.
The items within the repeat are shown at the proper location on the resulting map, but the data outside of the repeat is showing at (0,0). Is there a way to not have the data outside of the repeat use the location collected on each of the repeats? The data outside of the repeat doesn't change, so I don't want users to have to re-enter it each time, but it should be located at the same spot as the data within the repeat.
Kathy F
typenamelabel
notegenerated_note_form_title<p style="text-align:start;">Maui Fires 2023 - Logistics Assets and Resources</p>
notegenerated_note_form_submit_textSubmit
notegenerated_note_form_footer<a target='_blank' style='color:#000000;' href='https://www.esri.com/products/survey123'>Powered by ArcGIS Survey123</a>
notegenerated_note_prompt_submitted<p style="text-align:center;"><br></p><p style="text-align:center;"><img alt="Green check icon" src="data&colon;image/svg+xml;base64,PHN2ZyB3aWR0aD0iNjQiIGhlaWdodD0iNjQiIHhtbG5zPSJodHRwOi8vd3d3LnczLm9yZy8yMDAwL3N2ZyI+PGcgZmlsbD0ibm9uZSIgZmlsbC1ydWxlPSJldmVub2RkIj48Y2lyY2xlIGZpbGw9IiMzMTg3MkUiIGN4PSIzMiIgY3k9IjMyIiByPSIzMiIvPjxwYXRoIGZpbGw9IiNGRkYiIGQ9Ik0yMi42NjEgMzAuMjQ2bDUuMTgyIDQuOTg3TDQxLjU1MiAyMiA0NSAyNS40NjEgMjcuNzQ3IDQyIDE5IDMzLjQ5OHoiLz48L2c+PC9zdmc+"></p><p style="text-align:center;"><br></p><p style="text-align:center;"><br></p><p style="text-align:center;"><strong style="font-size:16px;">Thank you.</strong></p><p style="text-align:center;"><strong style="font-size:16px;">Your response was submitted successfully.</strong></p><p style="text-align:center;"><br></p><p style="text-align:center;"><span style="font-size:16px;">Contact <a href="https://www.alanaid.org/contact/" target="_blank">American Logistics Aid Network</a> for information.</p>
noteorganization_and_contact_informOrganization and Contact Information
textorg_nameWhat is the name of your organization?
textorg_urlWhat is your organization's website address?
textorg_pocWho is the point of contact for these resources?
textpoc_emailWhat is the contact's email address?
textpoc_phonePhone Number
begin repeatresourcesurveyAdd your locations and assets (click + to add more locations)
noteasset_resource_information_detaLogistics Resource Details
geopointresource_primary_locationWhat location are you reporting on?
select_multiple list_asset_resource_information_deta_asset_type1asset_type1What type of asset / resource are you offering?
textoffer_type_otherOther
select_one list_asset_resource_information_deta_donation_or_paid_offerdonation_or_paid_offerDonation or Paid Offer
textoffer_paid_otherOther
textresource_descriptionDescription of the resource or capability
end repeat
textadditional_informationAdditional Information
dateTimedate_and_time_submittedDate and Time Submitted
AaronPDXPaul
Here's my Excel.
I am willing to do this any way it can be done.
How can the Parent not be at (0,0)?
Thank you
DougBrowning
MVP Esteemed Contributor
Do you have a geopoint question in the parent at all?  You should
AaronPDXPaul
Can you provide an example of how I would do that? You are correct. There's no geopoint question for the parent. I am missing something maybe simple. Thank you again
DougBrowning
Well that is why you are getting the 0,0 then.  You need to add a geopoint to the parent.  With no question there it will default to 0,0 as you are seeing.  In general you always want a geopoint question.
AaronPDXPaul
Hi Doug.
Please see my Excel. We really appreciate your help
DougBrowning
Sorry just say this.  Simply add a geopoint to the parent section.
EmilySpeck
How do you inherit the parent geopoint?
DougBrowning
@EmilySpeck  You can just add the name of the parent geopoint into the calculation of the child geopoint I think.  Just like any other field.  Give it a try
EmilySpeck
I think I am having a issue with my pulldata calculation. I am using a CSV file to pull the information. It is reading the coordinates on Connect, but on AGOL it is reading (0,0). I attached a screenshot of my Connect form.
The CSV file is link media to my Connect, do I have to upload the file to AGOL as well?
DougBrowning
It could be the order of operations as the web can be different.  So its trying the repeat geopoint before pulldata loads.  Try putting a relevant on the geopoint in the repeat that makes sure the parent geopoint is not empty.
May have to try != "" and if not try string-length > 0
If that does not work try a relevant tied to one of the pulldata fields.
I would turn off hidden for now to see what its getting and when.  Always good for testing to see the values and hide later.
Hope that does it.
