Survey123 Repeat element on Survey123 report
2563
08-18-2023 03:46 AM
MoyinoluwaOlajide
Hi, I am trying to create a report that will put the repeats in a table row by row, but it keeps giving me error when I try to upload as a template.  I think I am following the syntax examples correctly.  When I try to load the report template, it gives me an error: "Failed to parse ${Key_Result_Areas} since Key_Result_Areas cannot be found in the current parsing scope."
 I have attached some screen shots and the xlsx form and report template.
Thanks, Moyin
Tags (3)
Katie_Clark
I think some things got messed up with your attachments. There's no report template (word doc) and the screenshots aren't working for me. Can you send again?
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
MoyinoluwaOlajide
Hi Katherine, is this better?
MoyinoluwaOlajide
