Survey123 Pulldata zoom to location
2453
08-21-2018 04:53 PM
deleted-user-8TVt6oc0ewsX
Is there a way to use PULLDATA to zoom to the location for a record in pulldata?  I want to read a barcode for an existing feature (sign) that has attributes in the media\*.CSV.  I then want to geocode an XY location that is stored in the CSV file and then show it on the map in Survey123.  A new survey record will be created at the new location.  Can this be done?
Tags (1)
ClaireProctor
Hi Jonathan,
If I'm not mistaken, the exact functionality you describe is covered in the 'Calculate Location from CSV' sample provided in Survey123 Connect.
Thanks Claire, can you point me to exactly where I can find this sample?  Where do I click to see it?
OK, I found it online but there is no option to download it.  Can you enable download or attach the file so I can see how this was done?  Thanks!
http://survey123.maps.arcgis.com/home/item.html?id=8767424aa9b745d98af62eab34808780
MichaelKelly
Hi Jonathan,
You can access the Samples via Survey123 Connect as below:
Mikie
Excellent, thanks Michael!  I was searching to enhance an existing survey, would have never thought about creating a new one to find these samples.
