Survey123: Pulldata() Using Another Existing Feature Service
21331
20
06-14-2018 11:59 AM
LeaHarper3
Hey! We are working on creating a facilities damage assessment/inspection application using an existing feature service in Survey123.
What we would like to do is somehow use the pulldata() function to pull data from another, different feature service to provide the options to select from (this would help to eliminate inconsistent building naming, address entry, etc). Is this possible to do, or is the only current option for pulldata() to work coming from a CSV file?
FarrahM
Hello,
Did you ever find a solution for this?
