Hello Philip,
That is correct. I update both the CSV and the “choices” tab in the XLSX form and then publish the updated survey for the inspectors to download on their devices. I am using Connect version 2.7.72 and Survey123 App version 2.8.2. We are using iPhones with the latest iOS version (11.4.1).
I forgot to mention: I unchecked “Export Data (Allow others to export to different formats)” in the “Settings” of the feature layer. It was after this action that I noticed the publishing changes not coming through to the app. Even after rechecking this option the survey is still not working properly though.
I have a work around but it’s not ideal since I lose all the tracking data about who submitted each survey on specific dates. If I use the option “create a new survey” on the current survey in Connect, the new survey will have all the new projects. However, I would prefer to have the current survey working again and not use this work around.
If this information doesn’t help you, I’ll ask my supervisor if I am able to provide you with the CSV and XLSX form.
Thank you for your help.
