survey123 publishing error -1: [object Object]
2630
7
03-24-2022 02:00 PM
PRATSIGTIERRAS
Hello,
I need help, when i'm publishing my survey123, i get this fail and when i see details just show me this:
-1: [object Object]
I coulnd't find anything about it.
Tags (1)
PRATSIGTIERRAS
adminaud
Hello, I got the same error, I hope someone can find a solution.
IsmaelChivite
Esri Notable Contributor
Hi. I am guessing you see this error when attempting to publish from the Survey123 web designer. Is this correct? I have seen this error appear before when I have a question with a calculation targeting a missing question.   Any chance you have invalid calculations in your design?
adminaud
Yes it's when I want to publish from the Survey123 webdesigner. I don't have any question with a calculation targeting a missing question...
IsmaelChivite
Can you try this?
  1. Go to the survey gallery and save your survey as a new one
  2. Publish the copy
Does it publish?
adminaud
No, still the same error
MauritsKoenders
Any updates on this? I just bumped into the same issue.
