survey123 or Collector for a field survey
356
07-11-2020 07:08 AM
by Anonymous User
Not applicable
If I want to collect data regarding different geographical or social parameters (for example, building types,occupancy, income etc) of a specific area or city. which tool should I use (COLLECTOR or SURVEY123). if answer is survey123 then can I exhaust all the responses from a single device for a field survey?thank you in advance for your response
by Anonymous User
Not applicable
Hi Rehan,
Depending on the types of questions, mapping capabilities and smart form features you want to use, will depend on whether Survey123 or Collector is more suited. You can also use a combination of both via app linking and custom URL schemes to launch one app from another, and pass attribute data between them.
In terms of your question "can I exhaust all the responses from a single device for a field survey?", what exactly do you mean by this? Please provide more details and explanation so we can respond accordingly.
Regards,
Phil.
