Is it possible (or planned to be possible) to use URL parameters to open an existing survey response in edit mode and ALSO pass a new value to one of the questions in the URL?
?mode=edit&globalId=<global id>&field:fieldName=SomeValue
I read through comments on blogs by Ismael Chivite but did not see an answer to this question, though one person did have this same question / use case.
Solved! Go to Solution.
Hi Tanner,
Supporting the field:<FieldName> URL parameter in edit mode is not currently in Survey123's roadmap. Could you file an idea at https://ideas.arcgis.com so that we can keep track of user interest on this?
Hi Tanner,
Hi @TanGnar
This will be supported in the next update of Survey123 in December. Could you please have a try then?
Jody Zheng Liu
Thank you for implementing this!!!
-dave o.
