Survey123 Mesa 3 Windows 10 Menu Problem
803
09-09-2020 06:04 AM
DeonLengton
Version information:
Windows 10  Version 2004 OS Build 19041.264
Survey123 Version 3.10.323
Issue: Survey123 installs correctly. Survey123 logs in correctly but the user is NOT able to click on the menu icon on the top right of the screen as indicated below:
When clicking on the Menu button nothing happens.
Without being able to access the Menu button the user is unable to:
- Sign out
- Download Surveys
- Access the Settings of Survey123 as shown below:
JamesTedrick
Esri Esteemed Contributor
Hi Deon,
This sounds very similar to BUG-000132152, which has been reported on a Mesa 2.  The issue is being looked at; if you want to add your case to the Esri BUG, we will be able to reach out once a fix is available for testing.
