Survey123 Map View Size
3512
6
04-10-2023 06:04 AM
JordanHolt
Good Morning,
Is there anyway to adjust the size of the default map viewer inside of Survey123 App? I am using Survey123 Connect 3.17. The View is pretty small and we would like for the field users to not have to open the map to get a better view. I have seen this question asked in the past but I did not see any update on this.
JordanHolt
We were able to get this to work using the percentage of the screen instead of height. Thank you for your help with this though!
Thanks!
ChristopherCounsell
MVP Frequent Contributor
Add defaultHeight=15 to the esri style binding?
Adjust as required.
JordanHolt
Thanks!
ChristopherCounsell
Hi @JordanHolt thanks for the update. Are you able to share more info on how you got this to work?
Thanks
JordanHolt
Magisian,
In the " body::esri:style " column we put " height=50% ". You can change this percentage based on the amount of screen real estate you are wanting to use.
Hope this helps!
ChristopherCounsell
Thanks!
Don't forget to mark your post as the solution too 🙂
MapsAreFun
Does this solution work in the web browser or only the app?  I have tried adding both defaultHeight=50% and height=50% to the body::esri:style field but it hasn't changed the height of my map. I would like it to work in the browser. Any ideas would be appreciated.
