Survey123: Is it possible to format a phone number?
19314
12
05-09-2019 06:04 AM
JordanMiller4
Is it possible to format a phone number? When the user starts to type the digits the form automatically adds dashes between 330 - 111 - 1111
Tags (1)
EgleAdmin
Any timeline for masks being added to web forms? @JamesTedrick
OTCGIS
If you are just looking to capture phone numbers in your Survey123 form you DO NOT need to use Survey123 Connect. The "NUMBER" form block does not support input masks, but the "SINGLE LINE TEXT" block does, so use the single line text instead of number block for capturing phone numbers and area codes.
bdejesus
I had to start and publish my survey from Survey123 Connect to achieve other calculations otherwise not possible in the Survey123 Web Designer. Just here to say it's almost 6 years later and masks are not respected in web applications. Someone please prove me wrong.
