I am using a workflow, tested an works on iOS devices but not Android devices. I will describe the workflow then the error i am encountering with Android devices.
Workflow:
- Use FieldMaps to Launch a New S123 form in the field app, using a typical hyperlink format.
- Certain parameters are pre-populated from the FM Feature Service I am launching S123 from (plant id, species, common name).
- User completes form, mashes send, then is taken back to field maps to continue on with the next form.
Issue (on android only):
- User is able to submit 2 forms. When they try to launch S123 a third time, S123 opens into a black screen.
- The only way to do the workflow (as designed) is to close everything.
I have had the user confirm both the application versions and software versions, and they are up to date.
This issue is only happening on Android devices; iOS works as designed. Closing an re-opening works, however the client needs to record and document over 700 individual trees, and it is unrealistic to ask them to close everything after every second record is submitted.
Has anyone else encountered this issue, and what was done to fix it?
