Survey123 | Inbox | Where code help needed
966
12-06-2021 09:37 AM
CarissaPhantom
What I have
AssignedInspector3 = ${username} OR highRISK='Contractor BMP Required'
Backstory: I have two different sub-contractors that each work in their own way.
Sub-contractor 1 - assigns an inspector to a point ---AssignedInspector = ${username}
Sub-contractor 2 - let's the inspector choose which site are closest to them --- highRISK='Contractor BMP Required'
I'd like to get the Sub-contractor 2 data to only populate the inbox if they belong to a specific company. Is there a way?
ZacharySutherby
Hello @CarissaPhantom
You'll likely need to use the concat() function to append quotes around the ${username} question. What I would suggest is
concat("AssignedInspector3 = '", ${username}, "' OR highRISK='Contractor BMP Required')
or even
AssignedInspector3 = concat("'",${username},"'") OR highRISK='Contractor BMP Required'
should work
Thank you,
Zach
CarissaPhantom
