Survey123 Inbox Spatial Filter from Workforce
907
03-17-2021 07:18 AM
David0044
I am opening an existing survey, passed from Workforce URL. Due to BUG-000137679, using the Action=Edit parameter, the survey opens in Inbox, rather than the desired record (from q:queryparameter).  However, it opens in the List View.
How do I set it to open in the Map View by default (spatial filter is turned on, and I can successfully access the map by button at the bottom of screen)?
Also, it opens on a default basemap, zoomed to max extent.  How do I set it to default open to the form basemap, zoomed to a reasonable level for the survey (e.g. street)?
