Survey123 Image unique name
2241
6
07-15-2020 08:50 AM
LiudmilaMaslova
Hello, everyone! I am working on Survey123 project, and I cannot get an image to acquire unique name matching instance name or date?
RobertBorchert
Honored Contributor
your row in the spreadsheet should look like the above.  the name should not contain special character other than underscore.  When you take the photo it should automatically attach date and time. Do you have editor tracking enabled on your feature?
LiudmilaMaslova
Thank you, Robert for replying
My editor was disabled. After, I have enabled Inbox I can see I have name "Picture 20200715-......" date backwards and a random number. Should I put a query to the query expression in Inbox like that image=${username}, so I can get user name as the name of the image?
Thank you
RobertBorchert
Honored Contributor
I have been trying to get something different into the image name and have not been successful. If you get something working I would love to see it.
I have my surveys set up to include the created_by so I it is in there.
RobertBorchert
Honored Contributor
It does the date backwards so they can be sorted alpha numerically.  If it was just a date you could sort by the date itself. so it will sort by year, month day, time.
LiudmilaMaslova
Hello, Robert
I found workaround way. I have decided to add a watermark to the picture with Data/Time. I added expresion in the bind::esri:parameters column as watermark=@[datetime:d MMM yyyy HH:mm]. Working well
Watermarks—Survey123 for ArcGIS | Documentation
RobertBorchert
Honored Contributor
Thanks I will look into it.
